Hello
I have a P5N-T Deluxe Motherboard. I have a Intel Quadcore, and 6GB of ram using a NVIDA graphics card.
Ever since I bought this Motherboard and built it it always! AWLAYS spontaneously froze up. At first i thought it was bad memory so started removing RAM and it still did it. After 3 years of dealing with this PC it finally shorted out and fried the board after my friend plugged in his ipod Via USB. I returned it RMA to ASUS and received another board same make and model.
After I received my new board i put it in my case connected all the components and BIOS wasn't posting( I called ASUS and the tech said it was a bad BIOS. I am not the stupid to take tech supports word for it so I spent hours trying to figure it out to come to a conclusion that its a short in the boear or with the scerws in the case).
I bench tested it and it worked fine COMPLETELY! I thought it was the case so i tried a different case. I got it to boot up and load windows but soon after it froze again, and then i was unable to get to load windows due to it freezing up. I took it all out again and as i type this i am using the board on my desk and it work FINE! Not a issue at all! What the heck?!
To try to pinpoint the short I left some of the gold foot holders in and started touching them with my screw driver to see if i was able to make it freeze up. No luck. no freeze. I even shook the board a bit to see if it would short out. NOTHING.
I recieved this new board just to have the same problems agian?! How can i solve this, its clearly a short because outside the case it runs perfect.
I was thinking of buying a new case but i didnt want to blow 40$ when I know i might run into the same problem.
What can I do to stop this from happening?
