I finished my first ever PC recently, I hooked it up to a monitor and tried doing a test boot, nothing would appear on the monitor and later I noticed that there was a red light above CPU and DRam on the motherboard. I'm fairly sure that all of the wiring has been inserted correctly and the parts have been installed correctly as well. My motherboard is a MSI - B350 PC MATE ATX AM4 Motherboard while my CPU is a AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor. The CPU cooler and system fans all function correctly when booted up too, is there any solution for this? I've tried making sure the CPU was installed correctly as well as running a double check on all the wiring. I've tried switching my ram from different slots too (currently on the closest one to CPU) but every time I boot up my PC, there's still two red lights above the tag 'CPU' and 'DRam' on my motherboard.
EDIT: So when connected to a monitor and powered up, there's no "No Signal" on the monitor unlike some other threads I've seen, all it gives me is a black screen. I've tried both HDMI and DVI ports as well as using two different monitors just to make sure one of them wasn't the problem.
