Motherboard Smoking and beeping. CPU fan doesn't start up.
Apr 7, 2018
So I recently purchased a new motherboard (B350M PRO-VDH) with a ryzen 3 1200, ram is viper patriot ddr4. Whenever I have the 24 pin connector plugged into the motherboard it starts smoking and repeatedly beeping. (Very light beeps, definitely does not sound like ones that come from the speaker. The smoke and the sound appear to come from 2 small metal circles just below the PCI E 1 slot (Video card slot) and the motherboard also gets very hot very quickly there. I have tried taking the ram out and nothing changes. I have also tried taking the motherboard out and have it on its side so nothing is touching the back, still nothing changes. I don't know what else to try.
You shouldnt be trying anything.
Send the motherboard back.
Send the PSU back.
Start over. Those are the two most likely components to be causing the issue. If you see smoke you should never try anything else other than replacement.
Send the PSU back.
I just bought a new PSU today and it ran my old board fine when I tested it. Will be sending the motherboard back, thank you.
