[SOLVED] Motherboard speaker volume too low ?
Superlp12
261
Just installed the 11900k on a Gigabyte z590 Auros Master motherboard. When I install the usual motherboard speaker, the beep that comes from it appears to be very soft. Wonder if this can be fixed ?
Hello @Superlp12
first of all, cleaning the speaker is another great idea to increase the volume if you feel PC volume is too low. Therefore, check the speakers from the inside and as well as outside and try to clean with a soft brush and cotton or vacuum cleaner. Be careful while cleaning the speakers as they have thin suction.
Hello @Superlp12
