Question Motherboard/System issue
Feb 21, 2019
6
Hello, recently I plugged in a DVD rom into my motherboard, since then the power led on case never turns off, and if the windows is inactive for like 4-5 hours, it shutdown/restart by itself automatically. But if I'm using it it never restarts unexpectedly.
I tried to install a fresh copy of windows, still didn't work
Updated drivers, didn't do the trick
Disabled fast shutdown, still persists
Can anyone help me?
computerjoe314
Upstanding
Jan 2, 2019
318
16
315
5
You might want to turn off your power supply when your done.
Then turn it back on when you want to use it.
See if that helps.
You might also want to do a BIOS update and see if that helps.
Similar threads
