Hello everyone!
I just installed a new motherboard today after my old one became faulty. The board in question is a MSI B150 Night Elf µATX. After putting all the components together and installing Windows, I checked temperatures with HWMonitor and while pretty much all components (CPU, SSD, GPU) were at or below 40°C including case temperature, the SYSTIN temperature of the motherboard reported 109°C (minimum) to 111°C (maximum). All other MB temperatures were fine (below 40°C). I then checked in the BIOS and since it is a relatively low feature board it only gave me CPU and SYS temperatures. Both below 40°C as well. I don't smell any burning smell and I also touched all heatsinks of the board directly after shutting down and unplugging everything (took me about 60 seconds) and none of them felt warmer than 40°C. Do you guys think this just a faulty reading due to lack of a sensor? If so, why would it hover between 109°C and 111°C? My system works just fine and I have enough fans in the case and on the CPU and I also applied new thermal paste to the CPU before putting on a powerful heat sink. Speccy also gives me the same readings.
Thanks so much in advance.
