Hello guys i have a problem, my motherboard GA G41MT S2 is shuting down whole computer, now it is realy unusual problem, when the computer is mounted on open rig case (workbench) it is working ok but when it is in closed case after ~15 min of gaming it shuts down and leave fan spinning.. I checked (changed) the cpu, ram,gpu, power supply its all fine, components are working ok and have normal temp.. but when the air gets hot in case it shuts down.. i changed paste on north and south bridges.. i check the temp on all of them and it is all fine the north brige is geting a little bit hot so i put the fan directly on it and it would shut down again (its not because of it).. i am geting rly confused and i have no idea what is wrong.. i suspect on some sensor that is corupted or damaged.. because if the air is geting around 33 celsius it would shut down.. I reinstaled windows I tried a lot of things that i cant all write 😀...
Its a moded motherboard with Xeon E5440
8 GB DDR3
HD 7870 2 gb
LC Power Supply 600W LC600H-12
Sorry for bad english..
8 GB DDR3
HD 7870 2 gb
