I need some advice installing a motherboard into my case. I was under the impression that the Panel1 on my ASRock 970M Pro3 motherboard connected to the Power button on my case. The problem is the Panel1 Slot has 9 pins in a row of 4 followed by a row of 5. According to the manual (http://66.226.78.22/downloadsite/Manual/QIG/970M%20Pro3_multiQIG.pdf) each set of pins has a function. I have an old case I received from my cousin it was a Gateway DX4200-09 the only components from the old Gateway i have are the case and it's built-in ports and fans. After plugging everything into the corresponding slots I noticed something very wrong. The power-button on the case had two cords, one being a twist of a blue and a white wire connecting to something next to the case's usb ports(I assume this cord is the speaker), and the other cord being a twist of a red and a white wire that ends in only two pins labeled "PWR-1." I have no Idea what to do as obviously 2 pins don't match 9 and I've never used this case so I don't know if the power button has an LED in it or not. There is what I think is a firewire port connected to a thick cord with 9 pins but they dont match with the Panel1 slot on the board. Other than that all other cords are where they belong.
