Your i7-860 Specs are: http://ark.intel.com/products/41316/Intel-Core-i7-860-Processor-(8M-Cache-2_80-GHz)
FORM FACTOR: Sockets Supported LGA1156
Radeon 7870 Specs are:
http://www.amd.com/us/products/desktop/graphics/7000/7870/Pages/radeon-7870.aspx#/3
interface: ◾PCI Express 3.0 x16 bus interface
So, we need a Intel Motherboard 1156 socket that supports the PCI Express 3.0 X16 ( assuming you only have one Radeon 7870!
Here are 3 but NOTICE they all have PCI Express 2.0 x16
Yes, PCI Express 3.0 is backwards compatible with PCI Express 2.0 slots.
Tiger Direct HAs these REFURBISHED. ( NOT SUGGESTED ):
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=13&sel=Detail%3B31_1259_47194_47194,Detail%3B31_174_53260_53260
These are on Amazon:
http://www.amazon.com/s/?ie=UTF8&keywords=intel+1156+motherboard&tag=mh0b-20&index=electronics&hvadid=859586041&ref=pd_sl_6f336r9e0d_e
The intel BOXDH55TC:
http://www.amazon.com/Intel-Socket-Motherboard-Retail-BOXDH55TC/dp/B002ZD6NBA/ref=sr_1_1/176-6979595-5430642?s=electronics&ie=UTF8&qid=1380274357&sr=1-1&keywords=intel+1156+motherboard
would probably be your best bet BUT keep in mind it is a MICRO ATX. The next step up would be the Intel BLKDH55HC :
http://www.amazon.com/Intel-Socket-DDR3-1333-Motherboard-BLKDH55HC/dp/B0033GFGKW/ref=sr_1_3/176-6979595-5430642?s=electronics&ie=UTF8&qid=1380274357&sr=1-3&keywords=intel+1156+motherboard
Your choices are VERY LIMITED if you stay with the i7-860 / 1156 series! Other than that I cannot help you much more! Good Luck
