A AquaTitanium Prominent Mar 27, 2017 3 0 510 Apr 1, 2017 #1 The motherboard I am planning on buying has a USB 3.0 header, but the case has 3.1 ports. Will this work?
Solution S S Suztera Apr 1, 2017 AquaTitanium : Suztera : Which case you talking about? Are you talking about usb 3.1 gen 1 or gen 2? The case is the Cooler Master MasterBox 5t. It has 2 gen 1 ports. Usb 3.1 Gen 1 is the previous usb 3.0 but now it is renamed to usb 3.1 gen 1.
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Apr 1, 2017 #2 Which case you talking about? Are you talking about usb 3.1 gen 1 or gen 2? Upvote 0 Downvote
A AquaTitanium Prominent Mar 27, 2017 3 0 510 Apr 1, 2017 #3 Suztera : Which case you talking about? Are you talking about usb 3.1 gen 1 or gen 2? The case is the Cooler Master MasterBox 5t. It has 2 gen 1 ports. Upvote 0 Downvote
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Apr 1, 2017 Solution #4 AquaTitanium : Suztera : Which case you talking about? Are you talking about usb 3.1 gen 1 or gen 2? The case is the Cooler Master MasterBox 5t. It has 2 gen 1 ports. Usb 3.1 Gen 1 is the previous usb 3.0 but now it is renamed to usb 3.1 gen 1. Upvote 0 Downvote Solution
