Motherboard? Weird noise
Pentium4User
411
137
Sounds like a fan bearing, or it may be a coil whine, try unplugging the fan and see if the noise is still present. If so then I pretty sure it a coil whine.
Oct 15, 2018
5
If it continues the sound, should I replace it or it wont make a difference except the noise
Pentium4User
411
137
Shouldn't make a difference and it should be fine, you just mite get annoyed by the sound.
