Motherboard will NOT POST! Need Help!!
kilianjames
8
I have just built my first pc, and I bought my parts looking off of affordable builds. Here's my specs:
-Asus M5A78L-M/USB3
-MSI R7 370 4g graphics
-AMD FX-6300 6 core
-2x4 memory
-1tb hdd
-500w POS
I have made sure to plug everything correctly, and when I turn on the power supply I get the solid green light on the mob. When I turn on the power via case button, everything starts up how it should. There's a speaker installed on the mob, but still no beeps or display on the monitor. I'm very desperate at this point, i've gone through countless trouble-shootings. Please help!
Just removed all ram, leaving just cpu, cooler, fans, and hard drive in the board. I'm not getting anything anymore, no green led or response when I press the power button
-update- the power supply to the mob was a bit loose, things power up again but still no beeps.
Yes it was on, I just didn't have the 20 and 4 pin connectors in all the way. Still no beeps without RAM though..
Hmm i've reseated the CPU like five times now so I doubt it's that. I've seen many similar problems on this exact motherboard, so maybe I'll return it and get another. Thank you for the support
But wouldn't the board start up with intergraded graphics regardless to a cpu issue? I'm just trying to narrow this down so I know which part to return.
