Question Motherboard will not work even after testing
Jul 13, 2019
My Gigabyte A320M-S2H motherboard has all of a sudden stopped working after I tried to change the direction of my cpu fan, I took the cpu out and just changed the direction of the fan and put the cpu back the same way it was and it slotted in like it should, I tested to see if the psu was fault as I hooked it up to another motherboard and I also tested the 24 pin connecter on the psu so I’m pretty convinced it’s the motherboard but I’m unsure how to fix it?
Jul 13, 2019
no power or something?
reseat the cpu? did you put in new thermal paste?
There’s power I jumped started the psu on another system I have and it worked and I reaseated the cpu about 3 times but I don’t have any thermal paste it’s not a very old cpu about 6 months so I’m not sure how that would help as I can’t even get the cpu off the heat sink to start
