Motherboard Wiring Help
Nuwatt
4
I've just recently bought a computer, and I've been able to install all the components (RAM, power supply, dvd drive, hard drive etc.) into their proper location. And after watching 2 youtube videos and looking for other thread help on this matter, I've still been lost on the wiring. When I say wiring, I mean the motherboard setup of wires, what connects to where, etc. The instructions book I have is apparently poorly translated from Taiwanese, either that or I'm just an idiot 😛
But yeah, I'm in need of some help on where to find how-to's specific to my motherboard, due to me not understanding this port table of contents. Here's what I have:
CPU - Intel Core i5-7500 3.4GHz Quad-Core Processor
Motherboard - MSI B250M MORTAR ARCTIC Micro ATX LGA1151 Motherboard
Memory - Team Dark 16GB (2 x 8GB) DDR4-2400 Memory
Storage - Toshiba 3TB 3.5" 7200RPM Internal Hard Drive
Case - BitFenix Nova ATX Mid Tower Case
Power Supply - SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply
Optical Drive - Memorex 98240 DVD/CD Writer
Case Fan - ARCTIC F12 PWM 74.0 CFM 120mm Fan
MSI provides well written and in-depth manual with all their MoBos to help you install your components.
Here's yours: https://www.msi.com/Motherboard/support/B250M-MORTAR-ARCTIC.html#down-manual
Select the English language one (3.53MB), download it, unpack it and start reading.
Page 6 is case front I/O connections. Page 8 is SATA drive connections (ODD, HDD, SSD). Page 9 is GPU connections. Page 30 to 34 is more in-depth about MoBo connections.
Wires that connect to your MoBo are:
1x 4/8-pin (to power CPU)
1x 24-pin (to power MoBo)
2x SATA (one for HDD, another for ODD)
1x front I/O connector (HDD led, reset button, power button etc)
1x front I/O audio connector (for mic and headphone jacks)
1x USB 3.0 (case front panel blue USB...
1x USB 3.0 (case front panel blue USB slot)
1x USB 2.0 (case front panel black USB slot)
1x 4-pin CPU cooler fan
1x 4-pin fan (Arctic F12 PWM)
1x 3-pin fan (stock 120mm fan that comes with the case)
All those above are covered in MoBo manual if you read it carefully. Oh, case fans go to SYS_FAN1 and SYS_FAN2 header and CPU fan goes to CPU_FAN1 header.
