Hello. I have not encountered a shortage of pins for fans before, as well as with backlight.
As far as I understood, it is better not to put even 2 coolers on 1 port through the splitter, especially more.
You can take a splitter with a cable, so that there would be power from the unit, this is more or less clear.
The model of the motherboard ASUS ROG STRIX Z690-I GAMING WIFI
The case of the jonsbo T8 plus is 1 - 140mm, 2 - 120mm, 1 - 92mm and processor coolers.
If you don't mind, look with an experienced eye at the connectors of the mother.
What is the best connection to make, including the backlight, too, at least so that all coolers do not overflow in different ways, but it is better that they are controlled.
For coolers of different companies, let's say the backlight will give out the same colors or should we take the same ones? Is management done programmatically? How does the backlight work, namely, its color transfusions occur randomly or cyclically? For example, if you just plant quiet illuminated valves at max rpm just through molex, will they overflow synchronously? If they are cyclically configured without adjustment, then the start of the cycle is taken from turning on the computer?
