Motherboard with no front panel connectors?
Corey_26
Commendable
Aug 30, 2016
4
Hi all. From work I got an old computer from a customer that's pretty decent and wanted to switch it to an old gaming tower I had. I know the thing will fit, but the case has all these cords for leds and the power button I think and I don't see where they'd go on the motherboard. Does this just mean I can't use that case?
Heres a pic of the motherboard (sorry if it's hard to see), the cords from the new case, and the motherboard specs - http://imgur.com/a/z8QHt
Let me know if you need any other info.
"Lenovo" - if the motherboard is from a OEM brand, there's a good chance it has custom interface to the front panel (eg Dells have it on a ribbon cable).
If you are lucky, you might be able to reverse-engineer the front panel connector (looking where each button and LED goes). You might also want to find service documentation for this particular Lenovo desktop.
It is OEM, I really hope that's not my only option though xD
Oh, I see you're right. It is slightly different though as mine only has 2 ram slots. Though I'm not sure what that adapter would be for. I see the Fpanel connectors but the guide does not specify what goes where.
