Hello,
i want to upgrade my MB from the Asus Z97-K to another one with excelent fan controls and eventually a larger space between the PCIe slots, for a SLI with Prolimatech MK-26 gpu heatsinks (if i can find a long enough and flexible SLI bridge. If it isn`t posible i will buy somethink like the 980ti Evga ACX, on top of the Mk-26 cooled one.
I want full pwm control over the fans, because i want a completely passive system under 50c and then a custom power curve. I`ve read that the ROG motherboards offer that option, but i want to know for sure.
The cpu is i5 4690k, the case is Corsair Air 540 (untill the Phanteks Evolv Atx Tempered Glass
launches)
Probably i will stick to Z97, as the price difference to X99 isn`t justified whatsoever.
Price mark would be ~200 euro.
Thank you!
launches)
Thank you!
