About a week ago my PC just completely shut off and died. One of my usb cables connected to the front panel of my PC somehow managed to get itself near my surge protector power strip and I believe touched one of the ports. There was a flash of light right before my PC dying and afterwards it would not turn on anymore. The end of my USB cable is entirely melted and charred with charred marks on the power strip.
So I opened up my PC to check inside, no burning smell. However when pressing the power button absolutely nothing would happen, no lights, no fans whirring, nothing. So I started trouble shooting.
First thing I did was check the PSU. PSU seemed fine, passed the paperclip test, had good voltage readings with a multimeter. But knowing that it might not perform well under load I used my GF's PSU (which works perfectly) and still no power to my PC.
I began breadboarding my motherboard with just the CPU, CPU fan, 8 pin connector + 24 pin connector. I attempted to short my mobo into starting using a flathead screwdriver + the two power start pins and still nothing. No lights no fans no beeping just dead quiet. So far not once has my motherboard given any indication that it was receiving any power.
So now I assumed that my motherboard was dead and sent it in to warranty/RMA to receive a replacement or get it repaired. A week later they sent a "replacement" motherboard and after breadboarding it and it not powering on again, I found out that they sent the same exact motherboard I had sent in. Same serial number and everything. Unfortunately I can't call them as they're closed to ask why they sent me the same one.
Have I missed anything? What else could be the problem? Or is it more likely that the warranty services just accidentally sent in the same motherboard?
