I left my PC without a PSU for 3 weeks while I was waiting for an RMA. When my new PSU arrived, it receives power for 0.5 seconds then powers off.
I decided to reseat all of my components then accidentally bent my CPU socket (rookie mistake). I then tried to run it without the CPU, but it powers on without any issues. All the fans are working.
I tried to use my brother's processor that is compatible with my motherboard, but it does the same thing before. It receives power for 0.5 seconds then continues to power off, regardless of bent pins (the CPU still goes all the way in). Do I need to be reassured that this is a motherboard problem? Or should I take extra steps to check if it's still a CPU problem?
BTW, my brother's motherboard does not support my CPU.
Needed Specs:
Intel i7-9700F
Intel i3-8100F (my brother's CPU)
Asus Prime H310M-E r2.0
Needed Specs:
Intel i7-9700F
