Motherboard won't read Memory ( RAM ) 4 beeps code (maybe front panel pins contact)
aneshamdani9
16
I just bought my new mobo which is a Chinese brand. So when I installed to to the case it wouldn't boot at all so i tried to find the problem and hey it was my PSU , i tried to change the PSU and yay it worked I had another 4gb ram stick that I need to use since I have windows 10 so i shut down my PC and installed the 4GB stick when I tried to boot it up i got a beep codes say it is memory problem(4 beeps) I took it to a local repair shop he said I might have damaged the motherboard when I was installing it and I remember when I tried to boot I up the second time I use a screw driver and had a little contact between the power SW and the reset SW . so what could be the problem ?
The Brand (first tech) haven't a website even nor a registered trademark and it does look like this :
http://
and a plastic was covering the cpu socket says FOXCONN lga1155 socket
Memory is guaranteed in the form sold. Other combinations you decide to make have no guarantee to be compatible together.
Modules sold as Singles also have no guarantee to be compatible together if used in multiples. This applies to exact match, same thing, identical.
Latest posts
