News Motherboards and systems with China's Loongson CPUs now shipping to US customers — options start from $373 for a DTX board with processor and cooler
The real question is whether you can build your own Linux kernel for it, or will it only boot a signed OS image?
The only way I'd even consider running something like this is if I could build the OS, with a mainline kernel, myself. I'm done running prepackaged software from China, which is why I won't buy anything higher-level than a KVM switch or unmanaged Ethernet switch from there.
It's a sad situation that we are getting ATX boards first for Loongson, but still none for either ARM or RISC-V. Only dev/beta boards.
It's like we're being punked and then getting laughed at.
I did not see in the article any mention of socket type so I assume these CPUs are soldered on.
Don't say there weren't ARM motherboards first:
https://www.gigabyte.com/Enterprise/Server-Motherboard/MP72-HB0-rev-30
The first is micro-ATX, the second is EATX.
Not sure why anyone would want this.. It's not even that cheap considering it's likely performce level.
You might be working for a Chinese firm that has to use them or write software for the platform.
I wouldn’t get one for personal use either as it makes zero sense since you can get something much more powerful that will run a lot more software with far fewer issues.
But who knows some other gorilla might get killed because a kid fell in its enclosure and loongsoon might be the dominant arch in 5 years
Yeah boards for Ampere Altra have been on Newegg over a year. You can buy a combo with the 64 core altra and board for like $1100 last I checked.
Reactions: bit_user
With mainline kernel support it should work booting your own kernel, haven't heard anything about it requiring images signed elsewhere.
But, it seems like you might need patches for all PCIe-drivers, to workaround their broken PCIe. As reported by phoronix:
https://www.phoronix.com/news/AMDGPU-Patches-Loongson-Bug
They wanted some fix to the AMD GPU driver merged into mainline, and:
Well that sounds like the usual re-ordering problems we have seen
patches for on Loongson multiple times now.
And I can only repeat what I've wrote before: We don't accept
workarounds in drivers for problems cause by severely platform issues.
Especially when that is clearly against any PCIe specification.
