Hi all, need help finding out what might be frying my motherboards.
I had an old computer which I recently relocated into a Fractal Design Define 7 case because I was planning on attaching 8 hard drives to it. It was an ASUS Sabertooth P67 with an i7-2600k 16 gb of memory and a GTX 1070. Used to be my gaming ring now repurposed as a home server since I no longer play on PC.
Last week I installed a SATA PCI Express expansion card to it and when switching the PC on again it worked for a split of a second and switched itself off.
I could not revive the computer. Tried all the things: CMOS clear different PSU, disconnect everything but CPU and memory to no avail.. The power stand by LED was on and the chipset ran hot but it would not boot. Not even the fans etc. I assumed that the PCI card fried it.
Fast forward a couple of weeks and I ordered a new motherboard, CPU and memory as a replacement. ASUS C246M PRO for its built in 8 SATA ports, i3-9100 and 2x8Gb DDR4 2400MHz memory. In order to test it out first I built it on top of the cardboard case it came with. Motherboard, CPU, memory. Then I plugged it into the spare PSU, switched it on and it booted. I could go into the BIOS, check temperatures and some other stuff. Everything looking great.
I then proceed to move the motherboard in the case. Plug in the PSU that I had in the case. Plug the case front IO panel (power and reset switches, audio and USB). Plug the case fan controller. Then I press the switch on button and again the motherboard boots for a split of a second before switching itself off. I start having a panic attack at this point.
I remove the motherboard from the case to test it with the previous PSU but it won't boot. Fried again. Interestingly the motherboard initially when it worked had 2 LEDs on even when powered off: the power standby and another one called ME (Intel management engine) but now that second ME LED is not switching on either.
So finally my questions are:
I'm thinking of going into a PC repair shop and ask them to test ALL of my components: both PSUs, CPU and memory, motherboard and even the case to try and understand what's causing this. No idea how much this will cost me though, but I don't want to RMA the motherboard only to fry the replacement, or to find out that my CPU and memory were also damaged (even though I guess I could also RMA these if that were to happen).
I'd have hoped modern motherboards would be more resilient? I've been building PCs for many years but this recent experience has left me incredibly disheartened. If I get a new motherboard and eventually PSU I think I might take it all to a shop for assembly as well.
Thanks for your help.
- what do you think is causing this? The PSU in the case is frying them? Could it be the case? Maybe one of the fan control circuits or the front panel? If so how come it started happening suddenly?
- What are the chances the motherboard can be salvaged? Could I return it for a refund? Technically speaking one could argue that I broke it by inadvertently plugging it into a faulty case or PSU
- What are the chances the cpu and memory are also damaged? I don't have a means to test them now
- Could I also return the CPU and memory even though they have been used? I guess that one will depend on my shop returns policy. And I'd have to thoroughly clean the CPU thermal paste.
