Motion Blur Reduction won't work, please help.
IsThisMyName
Commendable
Jan 5, 2017
20
Hi everyone,
So I just bought a LG 34UC79G-B and for some reason I don't see any difference when I enable/disable ''1ms Motion Blur Reduction''. The ghosting/Motion blur is really bad on this monitor and would like to know if I'm doing something wrong
Yes, it was 60hz when I first started it and changed it to 144hz immediately.
When I disable ''1ms Motion Blur Reduction'' I actually get less ghosting/blur.......what?! It is a little bit better now(after disabling it) but still, I would like to use the Blur Reduction feature to its potential...Do you know a fix/workaround for that? 🙁
Some images of the ''UFO Ghosting Test'' with 144hz and Motion Blur Reduction disabled
-https://gyazo.com/382420b0b1b0c2287f1f12753fadca41
-https://gyazo.com/ace83d3de6d9f018eda62222c45cf2ef
-https://gyazo.com/0397b16346e9b1137e9ca79be05aa2b3
MERGED QUESTION
Question from IsThisMyName : "Motion Blur Reduction won't work, please help."
