Mount and Blade Problems
magicman9836
69
So i have a dell optiplex 755
It runs windows 7 genuine
Specs:
Intel core 2 duo e6550 2.33 GHz
4 Gb ram
nvidia quadro FX 370 256 MB
any mount and blade plays like crap. Is there a way to fix this because this is more than enough to run those games at low settings
Well the are you playing mount and blade:warband ? that one has higher requirements and to be honest that video is junk for gaming. The drivers used are for 3d rending application so any gaming done will be much slower.
The best thing to do is upgrade your Video card or you can try install gaming drivers for that video card instead of the professional drivers.
