Mount Bitspower D5 Mod Top to 120mm Fan cut out
XPLOT1ON
89
need to mounting solution to the bitspower D5 Mod Top onto 120mm fan cut out. I did some research and found these two mounting bracket (Link Below). However I'm not sure if it will fit or not.
If you have a better solution feel free to comment :)
Bitspower D5 Mod top
EK-UNI Pump Holder (120mm FAN)
Alphacool pump mount universal for 120-140mm fans/radiators
Just an Update, I will be mounting my the Bitspower Mod Top in this style See Picture (instead of Reservoir it will be the Pump)
