The fan I have picked out is 20mm and the radiator is 35mm. The existing fan mount is about 15mm (it's rather bulky but this is to accommodate a removable fan filter). so that takes me to about 70mm give or take
So would I be able to directly attach the radiator to the fan? This should give me just enough room to install everything but I'm concerned I would need additional hardware to mount the radiator which would potentially make mounting this setup impossible.
