Hi everyone ,
i try to explain the issue as short as possible but sorry if it turns into a wall of text
A couple months a go i played alot of game on my pc that i put together but i got bored and took a few weeks break from the pc
after returning to the pc i realized that my mouse is behaving strange and it is not acting normal
the issue is that the mouse behave as if it has input lag or acceleration of some sort
for example this are the ones i noticed :
1: the small movements feels VERY strange and it is impossible so stop when you want to stop and it feels like when you stop moving the mouse goes a little more and then stops
2: sometimes the mouse is fast and sometimes it is very slow
3: the snap movements are fine
4: i was fine the first day but there was an update like 1 week ago for windows 10 and i think it messed things up after that
what i have tried :
1- i rolled back the windows update but no help there
2- fresh re-installation of windows 10
3- trying with 5 other mice with different brands
4- removing and updating the gaming software
5-making sure the fps and res is like normal
my system :
gpu : 1070 rog
cpu : 7700k
windows 10
ps: i know is sounds crazy because i used the word feel alot but after 3000 hours i can fully assure you that it is not in my brain , if i could just lower the sensitivity until it felt right i would but no matter how slow the sensitivity get the issue still happens
what i have tried :
my system :
gpu : 1070 rog
cpu : 7700k
windows 10
