Mouse Cursor Problem (Razer Naga MMO 2014)
Nedloh123
Hello. I have scoured the internet looking for a way to resolve my issue but with no luck. I have a problem to where my mouse cursor jerks towards the bottom of the screen when I lift my mouse (which I do a lot in most games I play). This is very frustrating and I would really appreciate a solid answer. My mouse is a Razer Naga MMO 2014 and my mouse pad is a Steelseries QcK Heavy. Thank you.
EDIT: The mouse is less than a month old
If it is just a month old i would just send it back to Razer, they will just send you a new one. I have the same mouse, but i have absolutely no clue what could cause that problem, it might be some dust or whatever in the sensor? I never lift my mouse though, maybe you could increase your DPI through...
If it is just a month old i would just send it back to Razer, they will just send you a new one. I have the same mouse, but i have absolutely no clue what could cause that problem, it might be some dust or whatever in the sensor? I never lift my mouse though, maybe you could increase your DPI through the Razer Synapse software so you don't have to lift it anymore.
