so i was almost full on space in my SSD so i decided to do a clean windows 10 re install and wipe all the old junk on my SSD. when reinstalling ran into problem installing saying can not install window on that drive so i bought a new SSD (samsung 500gb) and tried to install it same issue wouldnt install. turns out it was my second HDD file system not allowing it so bought the new SSD for no reason but kept it anyway and installed new window ... also bought new RAM vengence rgb pro 3200 2x16Gb so both of those things are new...
**Problem is now if my pc is under any load (ie starting up origins client or any program if i move the mouse i get a beeping noise in headset kinda like when you hold a key down for too long, (input overload) i never had this issue before i did the reinstall. from things i have been reading some say power issues some say xbox controller issues, and some say disable usb root hub property to have power shut off in device manager. im at my wits end as this was not a problem before a fresh install. i have a evga supeerNOVA nes650G says 80+ gold x370 gaming pro carbon mobo nvidia geforce rtx 2080. any ideas or suggestions is extremely helpfull and would be willing to hop in a discord or even zoom to screenshare to fix this thing
