Mouse jitter, but the mouse is not the problem.
isethi
11
i5, Win7 64-bit, 8gb RAM, HD7850.
Biostar h61mu3 (latest bios)
Untill last week I enjoyed my Logitech MX518 for years (a God among mice dare I say).
Since a couple of weeks I experienced mouse jitter.
When moving the mouse in a straight line my mouse would sometimes jitter all over the place. It would then stop for a couple of seconds/minutes when I just lifted the mouse from my desk for a second (the same movement you would make when you run out of desk space when you use low DPI).
At first I thought maybe either my mousemat and/or my mouse are dirty so I cleaned both. I even tried without using the mousemat (which I have done fine for years untill I got a mousemat), no fix.
I wasn't using the Logitech drivers (because I never experienced any problems before this), so I installed those to see if they'd make a difference, no fix.
Finally I figured maybe the sensor is just worn out (I think I had the MX518 for over 10 years). I went ahead and ordered the G400S. I got it last week but my mousepointer still jitters frequently.
I mostly work using high DPI (mostly the highest possible) and I know this increases mouse jitter somewhat but the thing is in all those years I have never experienced any noticeable jitter, so it simply can't be the high DPI.
I don't experience these issues when I use the same mouse on my laptop which lead me to believe it is maybe a problem with the usb ports (I tried all the ports, same problems on all of them) or the motherboard somehow.
I also tried raw input using the method described here:
http://www.esreality.com/post/1846538/markc-windows-7-mouse-acceleration-fix/
But that also made no difference.
I am out of ideas and frankly a bit frustrated, it's very annoying when I'm doing some precision Photoshop work for example.
I hope you have some thoughts and ideas for me, would be greatly appreciated!
G
If the mice didn't answer fine using Ubuntu, I'm pretty sure that it's a hardware issue from the laptop (not the mice).
I have some theories:
- a malware that infected the mouse.drv: 1) run the basic system scan on your antivirus, 2) go to Device Manager, uninstall the drivers of your mouse and restart the PC, 3) download and run HijackThis and send us the log file.
- radio wave interference along the mice wire: 1) check if there is any "new" source of high radio emissor near your equipment.
Thanks for your reply, sorry it took me a while. I followed your instructions, I did 1), 2), and 3). There are no new sources that could interfere with my equipment, I've a pretty empty desk. The scans didn't find any threats. Here is the HijackThis log:
Logfile of Trend Micro HijackThis v2.0.5
Scan saved at 1:50:24, on 8-4-2014
Platform: Windows 7 SP1 (WinNT 6.00.3505)
MSIE: Internet Explorer v11.0 (11.00.9600.16521)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Steam\Steam.exe
C:\Program Files (x86)\Skype\Phone\Skype.exe
C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
D:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDDaemon.exe
C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe
C:\Program Files\AVAST Software\Avast\avastui.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
C:\Users\Me\Downloads\HijackThis.exe
C:\Windows\SysWOW64\DllHost.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre7\bin\ssv.dll
O2 - BHO: avast! Online Security - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} - C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll
O2 - BHO: Aanmeldhulp voor Microsoft-account - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre7\bin\jp2ssv.dll
O4 - HKLM\..\Run: [IAStorIcon] C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
O4 - HKLM\..\Run: [VirtualCloneDrive] "D:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDDaemon.exe" /s
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [SwitchBoard] C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O4 - HKLM\..\Run: [AdobeCS6ServiceManager] "C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
O4 - HKLM\..\Run: [AvastUI.exe] "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKCU\..\Run: [Steam] "C:\Program Files (x86)\Steam\steam.exe" -silent
O4 - HKCU\..\Run: [Skype] "C:\Program Files (x86)\Skype\Phone\Skype.exe" /minimized /regrun
O4 - Startup: Adobe Gamma.lnk = C:\Program Files (x86)\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~3\Office12\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\program files (x86)\common files\microsoft shared\windows live\wlidnsp.dll
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O15 - Trusted Zone: http://*.hola.org
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O16 - DPF: {D4B68B83-8710-488B-A692-D74B50BA558E} (Creative Software AutoUpdate Support Package 2) - http://ccfiles.creative.com/Web/softwareupdate/ocx/15113/CTPIDPDE.cab
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) - http://ccfiles.creative.com/Web/softwareupdate/ocx/130321/CTPID.cab
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
O18 - Protocol: wlpg - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll
O20 - AppInit_DLLs: C:\Windows\SysWOW64\nvinit.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files (x86)\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: AMD External Events Utility - Unknown owner - C:\Windows\system32\atiesrxx.exe (file missing)
O23 - Service: avast! Antivirus - AVAST Software - C:\Program Files\AVAST Software\Avast\AvastSvc.exe
O23 - Service: BattlEye Service (BEService) - Unknown owner - C:\Program Files (x86)\Common Files\BattlEye\BEService.exe
O23 - Service: Capture Device Service - InterVideo Inc. - C:\Program Files (x86)\Common Files\InterVideo\DeviceService\DevSvc.exe
O23 - Service: Intel(R) Content Protection HECI Service (cphs) - Intel Corporation - C:\Windows\SysWow64\IntelCpHeciSvc.exe
O23 - Service: Creative ALchemy AL6 Licensing Service - Creative Labs - C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\AL6Licensing.exe
O23 - Service: Creative Audio Engine Licensing Service - Creative Labs - C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\CTAELicensing.exe
O23 - Service: Creative Audio Service (CTAudSvcService) - Creative Technology Ltd - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: FlexNet Licensing Service 64 - Flexera Software LLC - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe
O23 - Service: Google Update-service (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update-service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Intel(R) Rapid Storage Technology (IAStorDataMgrSvc) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
O23 - Service: @%SystemRoot%\system32\ieetwcollectorres.dll,-1000 (IEEtwCollectorService) - Unknown owner - C:\Windows\system32\IEEtwCollector.exe (file missing)
O23 - Service: Intel(R) Capability Licensing Service Interface - Intel(R) Corporation - C:\Program Files\Intel\iCLS Client\HeciServer.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NitroPDFDriverCreatorReadSpool2 (NitroDriverReadSpool2) - Nitro PDF Software - C:\Program Files\Common Files\Nitro PDF\Professional\7.0\NitroPDFDriverService2x64.exe
O23 - Service: Nalpeiron Licensing Service (nlsX86cc) - Nalpeiron Ltd. - C:\Windows\SysWOW64\NLSSRV32.EXE
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: PnkBstrA - Unknown owner - C:\Windows\system32\PnkBstrA.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: Adobe SwitchBoard (SwitchBoard) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O23 - Service: TeamViewer 9 (TeamViewer9) - TeamViewer GmbH - C:\Program Files (x86)\TeamViewer\Version9\TeamViewer_Service.exe
O23 - Service: TunngleService - Tunngle.net GmbH - C:\Program Files (x86)\Tunngle\TnglCtrl.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: Intel(R) Management and Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
O23 - Service: WTService - Unknown owner - C:\Windows\system32\atwtusb.exe (file missing)
End of file - 10655 bytes
Update your Java versione: http://java.com/en/download/index.jsp (if you use Java 64-bit, update it too (uninstall the old version first)).
After update, go the desktop and press Windows key + R, the Run windows will pop-up. Write 'msconfig' and press Enter. Go to the tab Startup and deselect TeamViewer 9. Go to the tab Services, look for and deselect TeamViewer 9.
Update your chipset: http://www.intel.com/p/en_US/support/detect
Report any news.
Could you download Ubuntu 12.04 LTS and make it bootable with a pendrive (use Universal USB Installer)?
Boot from the pendrive, choose the option "Test the Ubuntu" and test it a little (just open any program and waste 10 minutes).
The sibe of Ubuntu image is around 500mb; if it is not possible or will take too much time, ask me for another option.
Okay, took me a while to get the boot from usb working (my own inexperience), the mouse jitter is equally noticeable when I'm on Ubuntu. Does this mean it's a hardware issue? I can't be the mouse because it works fine on other systems, the problems remain no matter which usb port I use for the mouse. Do you have any more suggestions?
Yeah, thought so. Time to get some new stuff then! Anyway, thanks again for all your help!!
This is an old thread, but I recently had the same issue. Turned out to be my iPhone. I had the WiFi Hotspot on with the phone sitting on my desk next to the mouse. Once I turned off the Hotspot, it went back to working as expected. Thought I would share and remind folks to look for causes of communication interference when encountering this type of problem.
