Hello,
So I am having an issue where my computer, after playing something such as Rust, will make a beeping noise that is short and consecutive, as well as the mouse moving a few pixels every few seconds. The beeping however stops as soon as the program is closed via Task Manager. I have a bad feeling its my RAM because on the computers start up, my desktop sometimes loads a black screen before loading, OR it loads the desktop and then the actual programs I load, such as steam, will take 30 odd seconds to physically open. Once it has open however, the computer is very responsive as it should be.
Specs if needed:
CPU FX-8350
GPU GTX 760 2GB
RAM 8GB Patriot (The brand is obscure I know 😛) and I think it is 1600mhz (Not 100%)
I did read somewhere the desktop issue was a HDD error however I am also not 100% sure.
HDD Toshiba 1TB
I am going to be getting an SSD soon to make most programs load faster as well however so this may also fix it?
EDIT: I also checked in Event Viewer about both of the problems for a good half-hour and I couldn't find any error leading to them.
After each beeping error, I checked instantly and there were no errors leading to that aswell.
Thanks in advance,
George
Specs if needed:
CPU FX-8350
GPU GTX 760 2GB
HDD Toshiba 1TB
Thanks in advance,
George
