Mouse problem-Lag,slow downs
lok899
Commendable
Jan 7, 2017
18
Hi.I got a strange problem with my mouse its Connect It Biohazard mouse (i have it few years and no problem until now) but the problem is that when i open browser or opening some tabs my mouse slow downs (i dont press the DPI button) and in games like men of war assault squad 2 it lags and slow downs too so i hope someone can help me because its very annoying.It seems like the mouse slow downs when my PC is under load but i havent got the problem when i was playing Squad or mafia 2,3
Could be that your performance was on some threshold level.
What that means is that all is (was) well but then there was some small change in software, a driver, anything at all that pushed things over the edge and now the computer is laggy.
For "under load":
You can use Task Manager, Performance Monitor, and Resource Monitor to track down possible culprits.
Run and watch without the browser. See what all is going on with respect to running applications, services, processes and the resources being used.
Open the browser and again watch. Hopefully you will see some application, process, or service whose % use of a resource stays very high and thus interferers with/slows down other applications needing that resource as well.
If...
For "under load":
If you do not spot anything obvious then reinstall the mouse drivers and reconfigure the mouse to your needs.
well i havent saw anything obvious only superfetch is eating like 73 MB of ram but im sure its normal and WMI provider host uses 10-12% of CPU but well the mouse acts normally but sometime it slow downs.Ill try to reinstall the drivers maybe that will fix it
