Hi all. I just got a new mouse because my 4th one this month broke. I'm a gaming addict, so the mice really get worn out fast. This mouse, however, is a cheap one - but already has problems. So first off, with high sens - when I move the mouse really slowly to aim at something far away - if I move it just slightly, the crosshair doesn't move at all. If I move it just a bit quicker, it moves 2-3 pixels at a time. That was really annoying, so I lowered the sens as low as it will go before I'm completely immobilized. Now the darn thing has negative acceleration - or at least that's what I think it is. Basically, it feels like the sensor can't keep up with me when I move the mouse quickly - so it travels less than expected when I "twitch-aim". It's very annoying. Also, when turning around - if I do it quickly - the cursor not just covers less distance than it should, but also goes crazy, making circles instead of moving in a straight line. I have tried messing with the resolution, in hopes of affecting the DPI - but luck is not on my side. Also, I generally use a shelf as my mousepad (ROFL), so I figured it could be the culprit - but my tiny-ass mousepad doesn't fix the problems either. Anything you can suggest guys? P.S. the cheapo mouse is a Logitech M100.
