Question Move to a portable solution?
creature
25
My current desktop rig is ~4-5 years old and adobe Lightroom and Photoshop is running a bit slowly on it. I’ve done some testing and seems like everything is running fine, it just may be time for upgrade. Currently running Intel i5-9400F, G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-2666, 2 TB M.2 Solid State drive and a couple 1 TB HDD for backup/ longer term storage, and a GeForce rx570 Video Card.
I’m wanting to have a portable solution for travel and even just on the couch around the house. I don’t game and use it for photo editing of ~50 MB raw files. I’m looking at the ASUS ROG flow x16. Bestbuy has the 16 GB ram variant with i9 and 4060 card for ~$1800. From what I can tell I should be able to upgrade the RAM to 64 GB and be in a good spot. It seems ASUS isn’t the most popular but it is the only thing I’ve found to check the boxes for me. Using it as a tablet with stylus is highly desirable.
I’ve debated going to Apple but the iPad doesn’t run full adobe programs and the laptops don’t have touch screen for stylus use.
1) Any other options for having a table style or at least touch screen laptop portable solution? I liked my old surface pro table but lack of a GPU is steering me away. The surface studio laptop 2 is an option but expensive and reportedly runs real hot.
2) Is it worth maintaining the slower desktop as a storage rig or just migrate to the x16 with 1 TB and deal with managing data storage off of the unit?
3) how often are you upgrading/building new rigs? 4-5 years?
Maybe this might help:
and one of my friend uses his Tab S9+ exclusively for editing his photos with the stylus. Not the complete PC experience, but he says the stylus makes it a lot easier to outline and brush.
140mm fan for bottom intake, 120mm fan for lower side intake.
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor ($315.00 @ Amazon)
CPU Cooler: ID-COOLING IS-67-XT 67.58 CFM CPU Cooler ($39.99 @ Amazon)
Motherboard: Gigabyte B650I AORUS ULTRA Mini ITX AM5 Motherboard ($249.99 @ Amazon)
Memory: G.Skill Flare X5 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory ($199.99 @ Newegg)
Storage: Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($149.99 @ Amazon)
Video Card: ASRock Challenger D OC Radeon RX 6700 XT 12 GB Video Card ($329.99 @ Newegg)
Case: Phanteks Evolv Shift 2 Mini ITX Tower Case ($39.99 @ Newegg)
Power Supply: Corsair SF850L 850 W 80+ Gold Certified Fully Modular SFX Power Supply ($128.66 @ Amazon)
Case Fan: Corsair AF140L 67.43 CFM 140 mm Fan ($4.99 @ Corsair)
Case Fan: Thermalright TL-E12B EXTREM 78 CFM 120 mm Fan ($5.99 @ Amazon)
Total: $1464.58
Generated by PCPartPicker 2024-01-29 04:27 EST-0500
