S stormochangeo May 18, 2022 1 0 10 May 18, 2022 #1 i know this maybe such a goofy question , however i see that these optiplex's can now be transferred into an entirely different case , is it possible to maybe lets say put a 9010 or 3020's optiplex's motherboard into my optiplex 980?
Solution Ralston18 May 19, 2022 Perhaps..... You need to check the case specs and determine what motherboard form factors are supported. Then take some measurements and otherwise confirm that the motherboard will indeed fit. FYI: https://www.educba.com/types-of-motherboard/ Provided that I correctly identified your case it supports Mini Tower Form Factor https://www.hardware-corner.net/desktop-models/Dell-OptiPlex-980-MT/ = = = = You should likewise confirm that the motherboard also supports all of the components you plan to install. Reference the applicable User Guides/Manuals and visit manufacturers' websites for QVLs (Qualified Vendors List).
Ralston18 Titan Moderator Oct 11, 2014 39,458 4,405 146,290 May 19, 2022 Solution #2 Perhaps..... You need to check the case specs and determine what motherboard form factors are supported. Then take some measurements and otherwise confirm that the motherboard will indeed fit. FYI: https://www.educba.com/types-of-motherboard/ Provided that I correctly identified your case it supports Mini Tower Form Factor https://www.hardware-corner.net/desktop-models/Dell-OptiPlex-980-MT/ = = = = You should likewise confirm that the motherboard also supports all of the components you plan to install. Reference the applicable User Guides/Manuals and visit manufacturers' websites for QVLs (Qualified Vendors List). Upvote 0 Downvote Solution
