[SOLVED] MSI 2070 super 2 fan vs 3 fan?
The parts list is private...so I don't know what your build is/will be. That being said, go for the cad that you want to get, price wise or aesthetics wise. An additional fan on the cooling assembly only means better temps for the GPU but that will also mean more heat thrown into the inside of the chassis.
oops my bad I think this one should work https://ca.pcpartpicker.com/list/P7pM8M
