Question MSI 24” 144hz Gaming Monitor
May 3, 2021
4
Hello all...
I have an MSI 24” 144hz gaming monitor as my second display... and recently purchased a desk mount for both of my monitors.... says it mounts 17-27” displays... problem is, I can’t mount my second monitor because it only has 2 screw spots whereas my 27” monitor has 4 and mounts perfectly... is there a way to mount a 2 screw on a 4 screw mount?
Lutfij
Can you please parse the make and model(s) of both panels? One is stated to be from MSI and we know that it's 24" but what is the model for that unit? We will need the other panel's make and model as well. Also, include the make and model of the arm/mount that you're dealing with so we have more context to what you're looking at and how you're working with said hardware.
Reactions: silest
May 3, 2021
4
The exact 2 monitors I have are these:
LG 27GK750F-B - 27 INCH GAMING MONITOR
(Which mounted fine as it has 4 screw holes)
MSI Optix G24C 23.6" 16:9 144 Hz Curved FreeSync VA Gaming Monitor
(Which only has 2 screw holes)
My monitor mount I got:
North BayouNB-F160 17in - 27in Full Motion Dual Monitor Arm Desktop Mount
larsv8
503
91
19,240
58
I think your best source of info would be the amazon question and answers. I searched "mount" and there is quite a few discussions there and how people were able to make it work
