MSI 270X 4GB -Power
Bee_HD
Commendable
Sep 16, 2016
30
Hi, is it just me or is it impossible to power this card, it requires 2 6pin connectors and i simply cannot find any connectors for this card, my psu is the corsair cs750m.If you have links i would be greatful.
Thanks
Your PSU has
PCI-Express Connector 4 x 6+2-Pin, but it is modular, so you might need to find the wires that came with it and connect them to PSU and then GPU.
6+2pin is a type of wiring that can be used as either 6pin, or 8pin. For your card, you need two 6pin connectors, or two 6+2pin connectors, or one 6pin plus one 6+2 pin. In 6+2pin connections, you would have to connect the 6pin part, and leave the 2pin extension unused.
I tried that last time with 2x6pin+2pin amd it just fried the card? Couldnt i get 2x6pin to 6pin cables and use them? So one end of the 6pin would go in the psu and one would go in the gpu, but twice?
Are you using a modular PSU? If so one end will hook into the modular end of your PSU and the other end will hook into your GPU. Most PSU manufacturers very clearly mark which end of the cables go where.
As the cable on the right shows:
pcie6-2-jpg.57637
. The extra 2-pin makes no sense... And you got four of that type of cables you you're gonna power that GPU pretty well.
