So the CPU is a Ryzen 1700X, Stock Wraith CPU Cooler, (no OC) 16gb ram, Gigabyte Gaming 5 x370 gaming mobo, InWin Infinity 805 Case, Thermal Take Smart 7 700w PSU. Fans are: 120mm aigo, and the 140's are Fractal Design. Max fan settings for cpu and case via bios. Played Project Cars 2 with my pedal/wheel setup, and streamed with Streamlabs OBS, 720p, 30fps. So the computer will do it, and keep nice gaming FPS and Stream (it will do 1080p/30) ... however this thing is heating up my entire room! Alt-tabbing to the Ryzen Control Center showed CPU temp(s) around 80-85c. Also, seems like the MSI 390 card just runs much hotter and drawing more power than my older 1050TI.
In addition for streaming I use Process Lasso, to split the cpu cores between Streamlabs OBS and whatever game I am playing, typically WOW, WOW BFA Beta, Project Cars 2.
I posted this image before, but it shows my case layout with fans ...
Looking for help to get case temps down ... not just CPU, the entire case is just HOT!
https://flic.kr/p/LyiikG https://www.flickr.com/photos/145614895@N04/
Also if I want to add a second monitor, this GPU only has 1 HDMI out ... do I use a splitter???
