My PC Setup is Q6600(g0) stepping, no OC), Gigabyte p35c-DS3R Mobo, 4gb DDR2 memory, X OCZ GameXtream PSU, and etc. with Windows XP Pro 32bit. I recently purchased MSI ATI Radeon HD4890 OC (manufacturer part # R4890-T2D1G-OC). I previously had EVGA 8800 GTS 320mb, so these are the steps that I followed.
-Uninstalled the Nvidia driver from Control Panel
-Removed the Nvidia card -Installed the new ATI card
-Installed the catalyst drivers from the MSI CD, which is an older version than the AMD-ATI catalyst driver
However, when I restarted the computer, after the windows loading bar, the screen went black, so after searching around the forum, I found that it might be the partially left out Nvidia driver. So here are the steps I followed.
-Removed the ATI card
-Installed the old Nvidia card again
-I was able to go into windows, and there, using a driver removal software, I removed the Nvidia stuff that may have been left out.
-Took out the Nvidia card and reinstalled the ATI card
-Installed the MSI drivers from the MSI CD again, it was an up-to-date one according to their website, and it told me to use theirs
-HOWEVER, when I watched movies, and tried to skip scenes, it would freeze the computer... So I tried these steps:
-Installed the AMD-ATI driver this time, since one of the forum mentioned about AMD-ATI driver would be good enough, and it is more up to date.
-I thought everything went fine (I played games on these and watched movies, without the computer freezing, also I tried to OC the card, but brought it back to default, since I was afraid something might happen to it lol...)
-Then suddenly after some time (maybe two weeks), when the computer was turned on, the windows started with catalyst driver failure notification, but I was still able to watch movies and play games on it. The warning didn't come up for days. Then after a week or so, I saw the warning again, but it didn't happen again for a while.
-Above is my situation (too wordy.. sorry) Does anyone know why I get such errors?
-Should I keep the ATI drivers or try the MSI driver again (it did make my computer freeze, when watching movies).
-Is there anything else that I can try?
-Could it be physical defect associated with the card?
