MSI 760GMAP34FX cooler
jka1973
19
Trying to find a better more quite cooler for my system. Specs:
AM3+ MSI 760GMA P34 FX
AMD FX6350
Current heatsink came with AMD FX6350
My system seems to run really warm when playing a game, Idle temps currently are 18c to 22c, when i start a game it jumps to 54c, then after about 10 mins of play it jumps to 62c and gradually gets warmer.
It doesn't go above 73c so far.
I just upgraded the processor from a FX4300, those temps at idle were 32c and during game play would only go to 55c to 56c. I had a cheap after market cooler with the 4300, but it doesn't seem to cool the 6350 at all, with it on the 6350, the temps at idle are 43c and it jumps to 65c when i start a game, so i put the fan that came with it on, and thats the current temps as stated above.
I'm looking at getting a
CORSAIR - Hydro Series 120mm Liquid Cooling System, pre-filled and am wondering if it will work on this board?
Thanks in advance.
Yes, most aftermarket coolers come with kits for multiple platforms. Here you are looking at AMD AM2, FM2/2+ or AM3/3+ mounting they are all same.
http://www.corsair.com/en-gb/hydro-series-h60-high-performance-liquid-cpu-cooler
Package contents
Corsair H60 Liquid CPU Cooler
One 120mm fan
Mounting screws for fan and radiator
Mounting brackets for Intel™ LGA 115x/1136/2011 and AMD AM2/AM3/AM4/FM1/FM2
Quick Start Guide
