MSI 790FX-GD70 PCIe x1 card does not work in PCIe x16 slot
Master_Taco
20
I'm having a small issue with the way this motherboard seems to handle PCIe cards. As the title suggests, I have a MSI 790FX-GD70 motherboard, and I'm trying to install a PCIe x1 card (a Syba SD-PEX-EXPC PCI-Express to ExpressCard Adapter - which contains an AVerMedia HC82 Express-Card Hybrid Analog/ATSC) into a PCIe x16 slot on my motherboard. To my knowledge, any smaller card will fit -- and work -- in a PCIe slot that is larger than the card requires. The tuner card is confirmed working, and so is the adapter. The adapter and card work in the x1 slot on the motherboard, but my graphics card is an nVidia GTX 580 that I want on the first PCI x16 slot (instead of the second one). Does anybody know why this is not working, and do you have any ideas on how I can fix this?
Here is a picture of my motherboard, so you get the idea of where these cards are at, and where I'm trying to put them.
http://media.bestofmicro.com/6/C/206292/original/msi_790fx-gd70_top.jpg
(For reference purposes, in an ideal world this will be the order of the cards in my machine from top to bottom [right to left in the picture]): PCIe x16-GTX580;
PCIe x1-Empty (covered by GTX580);
PCIe x16-Radeon HD 4350;
PCI-USB Add-on Card;
PCIe x16-ExpressCard Adapter;
PCI-Empty;
PCIe x16-Empty)
and here is my DXDiag:
System Information
Time of this report: 2/24/2012, 04:22:55
Machine name: ************-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
System Model: MS-7577
BIOS: Default System BIOS
Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
Memory: 12288MB RAM
Available OS Memory: 12286MB RAM
Page File: 3840MB used, 20730MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Sound Tab 5: No problems found.
Sound Tab 6: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 580
Manufacturer: NVIDIA
Chip type: GeForce GTX 580
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1080&SUBSYS_15823842&REV_A1
Display Memory: 4063 MB
Dedicated Memory: 1503 MB
Shared Memory: 2559 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: AT240HP
Monitor Id: ATV0003
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.8562 (English)
Driver Version: 8.17.12.8562
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/15/2011 02:53:00, 15693120 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-53C0-11CF-807A-8E351FC2C535}
Vendor ID: 0x10DE
Device ID: 0x1080
SubSys ID: 0x15823842
Revision ID: 0x00A1
Driver Strong Name: oem35.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section030:8.17.12.8562😛ci\ven_10de&dev_1080
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Model: SMB2330HD
Monitor Id: SAM0710
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1080
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0889&SUBSYS_14627577&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6482 (English)
WHQL Logo'd: Yes
Date and Size: 10/18/2011 19:53:14, 2957544 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (2- Logitech USB Headset)
Default Sound Playback: No
Hardware ID: USB\VID_046D&PID_0A0B&REV_1013&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: Yes
Date and Size: 11/20/2010 21:23:47, 109696 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Description: SMB2330HD-1 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0018&SUBSYS_10DE0101&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.02.0024.0000 (English)
WHQL Logo'd: Yes
Date and Size: 7/7/2011 17:21:28, 174184 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Description: Headset Earphone (Headset (Afterglow Gamepad for Xbox 360))
Default Voice Playback: Yes
Hardware ID: USB\VID_1BAD&PID_F900&IA_01
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Realtek HDMI Output (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Realtek Digital Output (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (2- Logitech USB Headset)
Default Sound Capture: Yes
Default Voice Capture: No
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: CD Audio (Realtek High Definition Audio)
Default Sound Capture: No
Cap Flags: 0x1
Description: Line in at rear panel (Pink) (Realtek High Definition Audio)
Cap Flags: 0x1
Description: Stereo Mix (Realtek High Definition Audio)
Cap Flags: 0x1
Description: Headset Microphone (Headset (Afterglow Gamepad for Xbox 360))
Default Voice Capture: Yes
Cap Flags: 0x1
Description: Microphone (2- Microsoft LifeCam Show.)
Cap Flags: 0x1
Description: Line in at rear panel (Blue) (Realtek High Definition Audio)
Cap Flags: 0x1
Description: Line in at rear panel (Grey) (Realtek High Definition Audio)
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft eHome Infrared Transceiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Microsoft® LifeCam Show(TM)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0729
FF Driver: n/a
Device Name: Logitech USB Headset
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0A0B
FF Driver: n/a
Device Name: CP685AVR-G
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0764, 0x0501
FF Driver: n/a
Device Name: Razer Lycosa
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0109
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Controller (Afterglow Gamepad for Xbox 360)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1BAD, 0xF900
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4398
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/24/2011 21:29:26, 343040 bytes
| Driver: usbd.sys, 3/24/2011 21:28:59, 7936 bytes
+-+ USB Input Device
| | Vendor/Product ID: 0x1532, 0x0016
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| | Driver: hidusb.sys, 11/20/2010 21:23:47, 30208 bytes
| | Driver: hidclass.sys, 11/20/2010 21:23:47, 76800 bytes
| | Driver: hidparse.sys, 7/13/2009 18:06:17, 32896 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouhid.sys, 7/13/2009 18:00:20, 31232 bytes
| | | Driver: mouclass.sys, 7/13/2009 19:48:27, 49216 bytes
Gameport Devices
PS/2 Devices
+ Microsoft eHome Remote Control Keyboard keys
| Matching Device ID: hid\irdevicev2&col05
| Service: kbdhid
| Driver: kbdhid.sys, 11/20/2010 21:23:47, 33280 bytes
| Driver: kbdclass.sys, 7/13/2009 19:48:04, 50768 bytes
+ Microsoft eHome MCIR Keyboard
| Matching Device ID: hid\irdevicev2&col06
| Service: kbdhid
+ Microsoft eHome MCIR 109 Keyboard
| Matching Device ID: hid\irdevicev2&col07
| Service: kbdhid
+ HID Keyboard Device
| Vendor/Product ID: 0x0A5C, 0x4502
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/13/2009 17:19:57, 105472 bytes
| Service: mouhid
| Vendor/Product ID: 0x0A5C, 0x4503
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 21:23:47, 63360 bytes
| Driver: sermouse.sys, 7/13/2009 18:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 638.0 GB
Total Space: 953.8 GB
File System: NTFS
Model: WDC WD1001FALS-00U9B0 ATA Device
Drive: D:
Free Space: 0.1 GB
Total Space: 0.1 GB
File System: NTFS
Drive: E:
Free Space: 178.4 GB
Total Space: 610.5 GB
File System: NTFS
Model: ST3640323AS ATA Device
Drive: F:
Free Space: 9.8 GB
Total Space: 114.5 GB
File System: NTFS
Model: ST3120213AS ATA Device
Drive: H:
Free Space: 34.0 GB
Total Space: 95.6 GB
File System: NTFS
Model: Maxtor 6L100P0 ATA Device
Drive: I:
Free Space: 305.1 GB
Total Space: 305.2 GB
File System: NTFS
Model: WDC WD3200AAJS-22B4A0 ATA Device
Drive: J:
Free Space: 294.5 GB
Total Space: 953.9 GB
File System: NTFS
Model: Seagate FreeAgent Xtreme IEEE 1394 SBP2 Device
Drive: K:
Free Space: 32.2 GB
Total Space: 152.6 GB
File System: NTFS
Model: ST916082 1A USB Device
Drive: N:
Free Space: 143.0 GB
File System: NTFS
Model: ST31000528AS ATA Device
Drive: O:
Model: SONY DVD RW DRU-810A USB Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 21:23:47, 147456 bytes
Drive: L:
Model: DTSOFT Virtual CdRom Device
Drive: Q:
Model: ATAPI iHES208 2 ATA Device
Drive: P:
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_597A&SUBSYS_59561002&REV_00\3&267A616A&0&20
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 21:23:47, 184704 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_75771462&REV_00\3&267A616A&0&98
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:04, 25600 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:14, 325120 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:26, 343040 bytes
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_75771462&REV_03\4&16A7741&0&0028
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1002&DEV_5979&SUBSYS_59561002&REV_00\3&267A616A&0&18
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_75771462&REV_00\3&267A616A&0&90
Name: NVIDIA GeForce GTX 580
Device ID: PCI\VEN_10DE&DEV_1080&SUBSYS_15823842&REV_A1\4&345F2303&0&0018
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 224064 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 10/15/2011 02:53:00, 316496 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 10/15/2011 02:53:00, 15511 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 12971840 bytes
Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 10/15/2011 02:53:00, 68928 bytes
Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 2808128 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 24796992 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 7581504 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.8562 (English), 10/15/2011 02:53:00, 2232128 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 2542912 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 15693120 bytes
Driver: C:\Windows\system32\nvinfo.pb, 10/15/2011 02:53:00, 7384 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 24742720 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 8791360 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 10/15/2011 02:53:00, 61248 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 2458432 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 17248576 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 5578560 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.8562 (English), 10/15/2011 02:53:00, 2099520 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 2401088 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 13205312 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 18871616 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.8562 (English), 10/15/2011 02:53:00, 7041856 bytes
Driver: C:\Windows\system32\nvdispco64.dll, 2.00.0018.0000 (English), 10/15/2011 02:53:00, 1533248 bytes
Driver: C:\Windows\system32\nvgenco64.dll, 2.00.0013.0000 (English), 10/15/2011 02:53:00, 1454400 bytes
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1002&DEV_5956&SUBSYS_59561002&REV_00\3&267A616A&0&00
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_75771462&REV_00\3&267A616A&0&9A
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:04, 52736 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0E09&SUBSYS_15823842&REV_A1\4&345F2303&0&0118
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 21:23:47, 122368 bytes
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_75771462&REV_00\3&267A616A&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 19:48:27, 15424 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_75771462&REV_00\3&267A616A&0&92
Device ID: PCI\VEN_1033&DEV_00E0&SUBSYS_00021799&REV_04\4&2966AB86&0&3AA4
Device ID: PCI\VEN_1002&DEV_597E&SUBSYS_59561002&REV_00\3&267A616A&0&48
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_75771462&REV_00\3&267A616A&0&A1
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 19:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 19:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 19:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 21:23:47, 155520 bytes
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_75501462&REV_00\3&267A616A&0&88
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_75771462&REV_03\4&15C850D&0&0048
Name: NEC PCI to USB Open Host Controller
Device ID: PCI\VEN_1033&DEV_0035&SUBSYS_00011799&REV_43\4&2966AB86&0&39A4
Device ID: PCI\VEN_1002&DEV_597D&SUBSYS_59561002&REV_00\3&267A616A&0&38
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_75771462&REV_00\3&267A616A&0&A5
Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_75771462&REV_3C\3&267A616A&0&A0
Driver: n/a
Name: AVerMedia HC82 Express-Card Hybrid Analog/ATSC
Device ID: PCI\VEN_1131&DEV_7160&SUBSYS_04551461&REV_03\4&3374394A&0&0020
Driver: n/a
Device ID: PCI\VEN_1033&DEV_0035&SUBSYS_00011799&REV_43\4&2966AB86&0&38A4
Device ID: PCI\VEN_1002&DEV_597C&SUBSYS_59561002&REV_00\3&267A616A&0&30
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_75771462&REV_00\3&267A616A&0&99
Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_00\3&267A616A&0&A4
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3403&SUBSYS_577D1462&REV_00\4&141B75A6&0&0038
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/20/2010 21:23:47, 229888 bytes
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
Driver: n/a
Device ID: PCI\VEN_1002&DEV_597B&SUBSYS_59561002&REV_00\3&267A616A&0&28
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_75771462&REV_00\3&267A616A&0&91
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_75771462&REV_00\3&267A616A&0&A2
Name: Realtek PCIe GBE Family Controller #2
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_75771462&REV_03\4&A8A6DA8&0&0030
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
LogMeIn Video Encoder,0x00200000,1,1,racodec.ax,4.01.0000.2138
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
LogMeIn Video Decoder,0x00800000,1,1,racodec.ax,4.01.0000.2138
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
PlayReady DMO Wrapper,0x00600002,1,1,PRDMOW~1.DLL,1.03.2297.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
MS PR Source Filter,0x00200000,0,2,PRSource.dll,1.03.2297.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (2- Logitech USB Hea,0x00200000,0,0,qcap.dll,6.06.7601.17514
CD Audio (Realtek High Definiti,0x00200000,0,0,qcap.dll,6.06.7601.17514
Headset Microphone (Headset (Af,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line in at rear panel (Blue) (R,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line in at rear panel (Grey) (R,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line in at rear panel (Pink) (R,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (2- Microsoft LifeCa,0x00200000,0,0,qcap.dll,6.06.7601.17514
Stereo Mix (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Line in at front panel (Green),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Mic in at front panel (Pink),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (black),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (Blue),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (Green),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (Grey),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (Orange),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (Pink),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio CD input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
AVerMedia 716x BDA Analog Capture,0x00200000,2,3,ksproxy.ax,6.01.7601.17514
ManyCam Virtual Webcam,0x00200000,1,2,ksproxy.ax,6.01.7601.17514
Microsoft LifeCam Show,0x00200000,1,2,LcProxy.ax,3.20.0240.0000
Microsoft LifeCam Show.,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Logitech USB Headset,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
Headset (Afterglow Gamepad for Xbox 360),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
NVIDIA High Definition Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA HDMI Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio 2nd output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Source Filters:
AVerMedia 716x BDA ATSC Tuner,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
WDM Streaming TV Tuner Devices:
AVerMedia 716x BDA Analog TV Tuner,0x00200000,0,2,,6.01.7601.17514
WDM Streaming Crossbar Devices:
AVerMedia 716x BDA Analog Xbar,0x00200000,5,2,,6.01.7601.17514
WDM Streaming TV Audio Devices:
AVerMedia 716x BDA Analog TV Audio,0x00200000,1,1,,6.01.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
Device Control Filters:
AVerMedia 716x BDA Main Device,0x00200000,0,0,ksproxy.ax,6.01.7601.17514
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Headset Earphone (Headset (Afterglow Gamepad for Xbox 360)),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Realtek HDMI Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: SMB2330HD-1 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (2- Logitech USB Headset),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
Headset Earphone (Headset (Afte,0x00200000,1,0,quartz.dll,6.06.7601.17713
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
Realtek HDMI Output (Realtek Hi,0x00200000,1,0,quartz.dll,6.06.7601.17713
SMB2330HD-1 (NVIDIA High Defini,0x00200000,1,0,quartz.dll,6.06.7601.17713
Speakers (2- Logitech USB Heads,0x00200000,1,0,quartz.dll,6.06.7601.17713
BDA Receiver Components:
AVerMedia 716x BDA Digital Capture,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Slot's 1& 4 are linked and slots 3 & 5 are linked. While populating either slot 1 or 4 make sure the other does not have a card in it and same goes for 1 & 4.
Check again and see, I had this problem with one ATI card that it would work in 8X when I put it in CF with another same card in 1 & 4. Finally , I just flashed the second card with the firmware of the first card and , it worked fine at 16x.
Though in your case, that is not the option, just try the BIOS update for the Board. That might get it to work right.
I have not, but it didn't work in any of the other three x16 slots, so I didn't bother trying the fourth. I can do that, if you think it might work. And the Radeon is there to drive a TV across the room, yes.
Actually, all PCIe x1 cards aren't necessarily compatible with the PCIe x16 slots. We have seen that happen with a few Xonar cards, older ones. That could be the case since the documentation of your card (Syba) doesn't specifically mention it.
What you could go for is a PCIe x1 riser card and plug the syba into it from the PCIe X1 that is covered by the HS assembly of the GPU.
yhst-27518546784426_2199_87506186
http://www.amfeltec.com/products/x1pcie-riser.php
http://www.ably.com.tw/pdt/viewpdt.asp?absp=37&cat=PCIE_RISER
http://www.e-itx.com/a-alantic-single-pcie-x1-riser.html
I've seen risers before, but I don't quite understand how they would work in my case. From looking at them, risers are supposed to be screwed into the spare standoffs in a full sized case with, say, a micro-atx form factor motherboard. I have an extended ATX motherboard in a full-sized case. My motherboard has 7 total slots on the motherboard, that match the 7 slots on the back on my case. Am I missing something?
Like alyoshka mentioned, it's not 100%.
I'm assuming since the PCI-E_04 slot linked to PCI-E_01 slot, it might cause issue since you have GTX580 installed on PCI-E_01.
Before trying the riser you might want to unplug all your cards and play around with the slots combination. If it doesn't work if you put in last slot, i would assume it's compatibility issues. If you have other mobo to test your current setup would be better.
Yeah, I don't have one of those, because that would be convenient. Any other suggestions by chance?
I didn't totally understand that, what does PCI-E_01 have to do with PCI-E_04?
Why do you "want" the 580 in the top most slot?Any particular reason?
It will function fine in the slot that you've put the Syba Adapter in too... that's a 16X slot too.
You could put the Syba in the PCIe x1
Then the Radeon where it is
then the USB add on where it is
then the GTX580 (Where the Syba is)
That way all the cards will function at their designated speeds....
Well, there are two reasons for this. One, for whatever reason, when the GTX580 is not in the top slot, it performs at x8 speed (when under load, and without the Radeon card) and also, the motherboard shows post, boot menu, etc. on the first card in the motherboard. If the Radeon is the first card, then I have to go to the other side of the room, and turn the TV on to read anything on the screen when not in Windows 7. The POST screen, etc. is not mirrored on any other graphics card in the machine.
The problem is, the card does that when it's all by its self, in slot 3, the second x16 slot. at the time that screen shot was taken, the only slots populated were the x1 slot (PCIe #2 - adapter card), the second x16 slot (PCIe #3 - the 580), and the PCI slot with the USB card.
