Question Msi a320m pro vd/s VGA led On.
hishjr89
6
I started bulidng a PC and completed it. I'm pretty sure evry connection is right.
I have a ryzen 3 1200 CPU installed and 8gb ddr4 ram single slot.
When I power the system boots and fans are all spinning and the vga LED light ez debug is on and no display.
I'm using a VGA moniter and I've tried changing the ram slots and the hardrive and still no input the vga light stays on.
Ryzen 3 1200 can't show any input without gpu?
Should I try VGA to DVi ?
I need help please!!
hishjr89
6
You need to list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
In fact, are you using a discrete GPU at all?
No I'm not using a GPU at all,
Msi a320m pro vd/s Mobo.
Ryzen 3 1200
Gigabyte 500w 80+ bronze
Crucial ddr4 8gb 2400mhz
500gb sata WD
Antec vsk3000 chasis
I've read now that ryzen 3 1200 won't post without a GPU and the display should.be connected to gpu.
Cuz the EZ debug led only VGA is ON
The rest od the fans and everything is fine.
