Question MSI A320M VH PRO PLUS NO DISPLAY
May 15, 2020
6
Good day everyone!
I have a problem. My PC is less than a year and was perfectly fine until one morning it won't display anything, the gpu, cpu, and rgb fans are running and there's a beep sound from the mobo (3 beeps) and EZ Debug Led "VGA" indicator is on.
Specs are:
MSI A320m Pro Plus VH
GIGABYTE GTX 1050Ti
Ramsta 8GB DDR3 RAM
500w True Rated PSU
I tried:
  • reseating all the components except for CPU
  • Cleared CMOS either by Jumpering and removing the lithium battery
  • inserted 1 RAM stick insitead of 2 and changing the slot
I do not have any other unit to test the components so a quick guide will be appreciated.
Please do enlighten and help me out as it is driving me crazy now 🙁
Thanks
Good day everyone!
Specs are:
GIGABYTE GTX 1050Ti
Ramsta 8GB DDR3 RAM
500w True Rated PSU
I tried:
Thanks
Good day everyone!
Specs are:
GIGABYTE GTX 1050Ti
Ramsta 8GB DDR3 RAM
500w True Rated PSU
I tried:
Thanks
Good day everyone!
Specs are:
GIGABYTE GTX 1050Ti
Ramsta 8GB DDR3 RAM
500w True Rated PSU
I tried:
Thanks
Hi all,
I gave a bit of a problem with my pc that is driving me nuts. It was working fine last night and turned it off properly. This morning it won't boot, there's a beeping sound in my unit and when I checked, EZ LED light indicator shows VGA ON. Beeping sound is 3 beeps (i think 1 long and 2 short beeps).
I've tried reseating the ram and gpu, but no avail. Tried removing one ram stick and changing its slot location, no avail too. So I decided to clear cmos by removing the lithium battery for almost an hour and also doing Jumpering when I failed, both steps didn't help. I'm running out of idea on what to do, I just don't have any spare ram stick or unit to test the components.
Specs:
  • Ryzen 5 2600
  • MSI A320M PRO PLUS VH mobo
  • RAMSTA 8GB DDR4 (2pcs)
  • GIGABYTE GTX 1050ti
Hope you can help me out.
