MSI B150M Pro-VD LGA 1151 Intel B150 SATA 6Gb/s USB 3.1 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130895
Above is the motherboard I have. I just built my PC at the end of June this year, and it has been working perfectly until now. The mobo has a built in LED feature "EZ Debug LED" and the DRAM LED is lit up. Obviously my Memory is the issue, but what's the best thing to do here? Should I remove it and snap it back in, then try to boot up my comp again? Is there something else I should do first - and what should I do if removing it and placing it back in doesn't work? Here is the RAM I have:
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231888
