Assembled and breading-boarding new PC; CPU, Cooler, PSU and Ram all seated correctly.
Entire build has been troubleshot, I believe the RAM is potentially faulty (DOA). Have tested all components one by one but still confused as to whether MOBO or CPU is potentially faulty aswell... I swapped out RAM for some from a computer that is working fine. Usually the computer turns on, cycles passed CPU freezes on DRAM for 5 seconds and then all LEDs are off however upon swapping RAM and seating, EZ Debug LED light changes to flashing between CPU (one second) back to DRAM (another second) on a continuous loop.
Components are as follows:
- MSI B250M Bazooka
- Corsair VS 450 [PSU]
- i3 Intel 7100 (Kaby Lake) + Stock cooler
- 8GB Corsair DDR4 Value Select, PC4-17000 (2133), Non-ECC Unbuffered, CAS 15-15-15-36, 1.2V
[REPLACED FOR TESTING W/]
- x2 8GB Vengeance LPX DDR4 Black 2666Mhz C16 1.2V
Open to any suggestions, thanks in advance!
- MSI B250M Bazooka
