MSI b350 gaming plus and ryzen 5 2400g no signal with hdmi or vga!
Power is there and all cables are plugged in. I am using an apu so it shouldn’t be me not having a gpu I have 8 gn of ram and ive tried them in both slots... still no signal. The motherboard does have a debug led lit up on vga. Please help!!
maybe psu failing but see some tips below
check .
1. motherboard bios is update to latest and check the ram are working and are comaptible with cpu and mobo .
2. your monitor is new one.
3. you are using only the digital ports for display.
if you have a very old monitor () then you might have to buy a new one or use a active display adapter(such as vga to dvi-d/hdmi OUT).
most probably bios update should fix the no signal problem.
Also you may have to wait for a while for the display to come after that
check .
