MSI B350 Gaming Pro Mystic Light with GSkill TridentZ
maiden5399
7
Hey guys,
I was wondering if there is any fix for the RGB sync that is working for you guys
Currently using:
B350 Gaming Pro Carbon
2x8Gb G.Skill TridentZ 3000mhz
Whenever I run the MSI Gaming app, the rams are not showing.
https://imgur.com/a/f90tE
Is there any BIOS settings required or is the TridentZ not supported by MSI yet?
Yeah. Just tried the G.Skill app. Apparently my rams were not detected in slots 2 and 4. Swapped it to 1 and 3 went into a bootloop. Guess ill just stick to what i have for now then
I also have the same problem with similar equipment. I have the MSi b350 Gaming Pro M-Atx with 2x16gb trident Z ram at 2400 mhz. I also cannot get mystic light to see the ram, nor will the trident Z software see the modules.
Any help would again be appreciated.
