MSI B350 Tomahawk first time booting/display problem
actssassin
14
Hello My build is:
Ryzen 1600
Asus GTX 770 4gb
MSI B350 Tomahawk
4 GB 2400mhz ddr4 crucial ballistic sports
1 TB 7200 Hdd (from old pc)
External usb device with windows 10
Hey so I installed all the pc parts. Had my gpu connect to my TV via hdmi. Keyboard and Mouse through usb (All of them i tried). I powered on pc, all fans started spinning.
Problems:
1) My TV says no signal, I tested my laptop with my tv via same hdmi cable it worked.
2) I tried to press Del repeatedly on keyboard, no response. Realized keyboard isnt powered because no lights would turn on.
3) I had the Boot led (in the ez debug led panels) lit red. I havent connected my external drive yet.
All other led in ez debug is off meaning my cpu, gpu and ram is detected and working.
So how do i fix this problem ? Is it because my system is bad and can't boot? Is it because I need a different keyboard (I used this one for laptop and old pc)? I have tried my brothers keyboard which had same problem.Is it my tv?
try to wait one minute after booting it. Before bios update my b350 gaming plus ,i did wait 1 minute...
Hey my psu is semi modular evga 500 bq. Pc part picker listed it as compatible.
Also I connected my speakers to the audio port and I restarted system everything is same as it was. I didn't hear any beep
My monitor only has vga which my gpu doesn't support. I ordered for an adapter to hdmi which will come in tmmr. Meanwhile I want to know if there is a system problem rather than a system problem since even my tv doesn't work.
try to wait one minute after booting it. Before bios update my b350 gaming plus ,i did wait 1 minute before it start
