Question MSI b350 tomahawk Red led cpu
Dec 30, 2020
7
Hello i have problem with starting my pc. No screen. Im using ryzen 5 1600 and on mobo there is Red led CPU all time.
Tried clearing CMOS. What's also strange that only 1 fan is working of 2 in my graphic card 7970. I event bought 580 and for a second 1 fan is working.
So i dont know what is broken, CPU, psu or mobo... :/
has it ever worked?
did you recently change any hardware? or update BIOS?
do you have a spare GPU? if so, try swapping out that 7970 and to see what happens.
Make sure you're connecting the display to the GPU and not the motherboard connector.
Are any of the trouble LED's lighting? If you have one you can also connect a speaker to the speaker pins and it might sound a beep code to help troubleshoot.
Well, CPU LED is lightning but no sound from speaker
I checked other psu from friend and its working. CPU or motherboard is dead but how to check now
